Please help. I am looking for a supplier for case components like fan mounts and hdd cages.
Ibrokeitagain89
Commendable
May 10, 2016
Hi guys,
Got a slightly different one for you. Hope you can help.
I've started to build desks that hold and show off pc components, with built in cooling systems etc... Until now, I've recycled parts from old cases.
I'm looking for a supplier for things like hdd cages. Square mounts to fit fans into wooden panels, so a 120mm fan can fit inside a 120mm hole and screw into a small mount which is fixed into the wood, leaving it flush if that makes sense.
I also need the L shaped frame at the back, that the motherboard connections and gpu outputs fit onto.
Basically, I need all of the internal parts of a case, without having to buy a tonne of cases and throw the frames away. I can't find anything online. I'm based in UK, but shipping from overseas isn't a problem.
Thanks in advance
let me clarify, so youre looking for the rear gpu mount and I/O plate bracket, I assume in metal or plastic so that it can then screw into the desk. Then you want fan brackets so that the fans can suit inside a hole that youre cutting, and then you want HDD/SSD cages
