Question Please help. I get low FPS in COD Warzone (RTX 2080, Ryzen 3700X, 32G Ram at 3200 Ghz)
Aug 29, 2021
Any help will be welcomed.
I am sure something is not setup right, as I am getting an average of 80 FPS in COD Warzone with a system that supposes to be decent...
Video Card: Gigabyte GeForce RTX 2080 SUPER
Processor AMD Ryzen 7 3700X 8-Core Processor 3.59 GHz
RAM Corsair Vengeance LPX DDR4 3200 C16 2x16GB running at 3200MHz
Motherboard: B450 Aorus Elite
Operating system Windows 10 64-bit
The game is running from an SSD
I play on a 2K monitor, but I don't see a difference in FPS even when I lower the resolution, making me think I am CPU bound.
Benchmark:
Images from my system:
https://ibb.co/X4n5nkW
https://ibb.co/82h5GY5
RAM Corsair 32G (16Gx2) 3200MHz
I forgot to add a link for a benchmark:
https://www.userbenchmark.com/UserRun/45843503
Aug 29, 2021
All looks good. Are other games ok?
I just tried to load Battlefield 1, and I get 40FPS on medium settings... (I'm not familiar with the game, it was the 2nd time I ran it)
Is the gpu and all motherboard drivers up to date?
The GPU drivers are the latest (August 10th)
I am Not sure what are motherboard drivers but the bios firmware is from January which I think is the latest.
and I just checked Windows update and it is update
Battlefield 1 isn’t running right either.
There will be several drivers for the motherboard on the support page for the motherboard.
When gaming what speed (GHz) is the cpu running at
Aug 29, 2021
I have just had a thought, do you have Ray tracing on? If yes then turn it off.
Ray tracing is off.
I do play on 1440p. There is not one place where you can set high/medium/low settings in this game, each graphic property has its own setting. I use the settings Nvidia experience recommended.
But even when i set everything to low and the game looks like a mobile game the maximum I gain is another 5-20fps.
