First I have FX-8350 and R9-280X with 750w PSU When I started my computer everything seems to be normal 0%-2% GPU and 25-35C on temperature, but after 6-10 mins (Idle) GPU activity keeps rising to 70% - 80% same goes with temperature. It's never happened before I can run many heavy games smoothly ( GTAV, RB6S, Crysis 3 ) but after a couple of minutes, FPS instantly dropped from 200+ to Unplayable.
Here's the list what I've done so far
- Use Process Explorer to find some suspicious activity like Bitcoin Miner nothing found; I even ended some important background applications, and nothing is using my GPU ( This is fresh install updated Windows 10 )
- Clean re-install AMD Driver with AMD Cleanup utilities and even use DDU after that. ( The problem seems to be fixed when I don't have a driver on my computer )
- Scan computer with Windows Defender / Malwarebytes no threat found.
- Try different driver version 15.7/16.9.2/16.1.10/16.6
- Disable Audio Bus driver in devmgmt.msc
- Reset Crimson to factory setting.
Here is some more information.
- I don't Overclock
- Fresh Install Windows 10 with only Steam and some Adobe software (License)
- I don't do Torrenting.
- No dust since I have OCD like to keep everything clean as possible.
- The driver also alerts me with "Radeon settings has detected that one or more high DPI panels connected to your system. Enabling virtual resolution will increase your resolution and allow you to customize your dpi settings.." which is never happened before until last night.
- When I uninstall a driver, everything is fine, but whenever I installed it back, the problem still occur.
My computer task list.
I have to use computer without AMD Driver right now because I can't stand a GPU fan sound, If you see anything suspicious, please tell me much appreciate guys Thanks a lot 😀
- I don't Overclock
System Idle Process 0 Services 0 4 K
System 4 Services 0 804 K
smss.exe 428 Services 0 1,176 K
csrss.exe 540 Services 0 4,312 K
wininit.exe 620 Services 0 5,252 K
csrss.exe 628 Console 1 9,812 K
winlogon.exe 704 Console 1 9,092 K
services.exe 752 Services 0 7,960 K
lsass.exe 760 Services 0 14,876 K
svchost.exe 864 Services 0 22,252 K
svchost.exe 932 Services 0 10,280 K
dwm.exe 364 Console 1 71,720 K
svchost.exe 488 Services 0 22,732 K
svchost.exe 496 Services 0 53,900 K
svchost.exe 916 Services 0 81,820 K
svchost.exe 1192 Services 0 25,972 K
svchost.exe 1340 Services 0 21,908 K
svchost.exe 1516 Services 0 18,632 K
svchost.exe 1684 Services 0 9,668 K
svchost.exe 1772 Services 0 7,212 K
spoolsv.exe 1868 Services 0 17,052 K
armsvc.exe 2080 Services 0 6,504 K
AdobeUpdateService.exe 2092 Services 0 6,524 K
AGSService.exe 2100 Services 0 11,212 K
OriginWebHelperService.ex 2116 Services 0 21,744 K
svchost.exe 2192 Services 0 8,884 K
ViakaraokeSrv.exe 2200 Services 0 6,056 K
svchost.exe 2208 Services 0 17,000 K
TeamViewer_Service.exe 2248 Services 0 17,724 K
MsMpEng.exe 2260 Services 0 171,184 K
svchost.exe 2288 Services 0 28,760 K
plays_service.exe 2400 Services 0 24,400 K
Memory Compression 2544 Services 0 36,064 K
sihost.exe 3428 Console 1 21,648 K
explorer.exe 3552 Console 1 100,376 K
NisSrv.exe 3884 Services 0 11,552 K
svchost.exe 3948 Console 1 33,492 K
taskhostw.exe 3396 Console 1 19,228 K
RuntimeBroker.exe 4104 Console 1 36,624 K
ShellExperienceHost.exe 4200 Console 1 66,072 K
SettingSyncHost.exe 3244 Console 1 3,540 K
MSASCuiL.exe 2396 Console 1 13,304 K
OneDrive.exe 1540 Console 1 25,016 K
Steam.exe 3900 Console 1 66,928 K
acrotray.exe 5332 Console 1 8,284 K
playstv.exe 5628 Console 1 15,428 K
dllhost.exe 5720 Console 1 10,500 K
steamwebhelper.exe 5800 Console 1 26,944 K
SteamService.exe 5920 Services 0 13,692 K
plays_ep64.exe 5528 Console 1 9,544 K
chrome.exe 2224 Console 1 222,992 K
chrome.exe 2012 Console 1 8,004 K
chrome.exe 5192 Console 1 9,536 K
chrome.exe 2672 Console 1 142,932 K
chrome.exe 4808 Console 1 39,272 K
chrome.exe 4724 Console 1 40,220 K
chrome.exe 2316 Console 1 68,896 K
chrome.exe 5256 Console 1 52,252 K
MpCmdRun.exe 6428 Services 0 11,192 K
chrome.exe 6596 Console 1 283,216 K
WmiPrvSE.exe 640 Services 0 13,208 K
svchost.exe 6480 Services 0 7,028 K
chrome.exe 7236 Console 1 274,324 K
OfficeClickToRun.exe 560 Services 0 57,932 K
AppVShNotify.exe 5940 Console 1 8,148 K
SearchUI.exe 3876 Console 1 117,304 K
SearchIndexer.exe 3956 Services 0 21,780 K
OSE.EXE 1336 Services 0 4,372 K
ApplicationFrameHost.exe 3204 Console 1 21,996 K
SystemSettings.exe 4776 Console 1 36,536 K
chrome.exe 2272 Console 1 302,216 K
SystemSettingsBroker.exe 6876 Console 1 13,812 K
chrome.exe 1244 Console 1 311,276 K
smartscreen.exe 3976 Console 1 13,700 K
cmd.exe 6240 Console 1 3,044 K
conhost.exe 6516 Console 1 14,864 K
sppsvc.exe 6940 Services 0 19,280 K
SppExtComObj.Exe 4444 Services 0 9,280 K
tasklist.exe 1928 Console 1 7,896 K
