Please help im a pc building noob!
Sep 22, 2018
Hello people
So basically im planning on building a pc for the first time and i have a question:
Im planning on using an intel i3 8100 cpu as i really cant spend too much. Ive also looked into gpu's and i really like the gtx 1060, but will i end up bottlnecking my system as im only using an i3? Ive decided its worth the extra money for a 1060 compared to a 1050 ti if its working to its fullest, but would i be better of with the 1050 ti if the i3 is holding the 1060 back? I intend to use it for gaming and schoolwork, so i dont really need a super powerful cpu, but i want to get the gpu working to its fullest. The 1060 would be about 40-50% of the total cost, which sounds quite high, thats why im asking this. Also would ypu have any suggestions for motherboards to use for this combo as i havent quite decided yet
If you can help its greatly appreciated (and sorry if im a bit of a noob)!
I3 8100 won't bottleneck GTX1060, but that's probably as far as you can go without the bottleneck. I highly suggest you pay the extra for a 1060 over 1050ti if you can, because the gap is pretty big. You can also consider 1060 3GB or a 970.
CPU: Intel - Core i3-8100 3.6GHz Quad-Core Processor ($118.90 @ B&H)
Motherboard: ASRock - B360 Pro4 ATX LGA1151 Motherboard ($69.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-2400 Memory ($69.99 @ Newegg)
Storage: Kingston - A400 240GB 2.5" Solid State Drive ($45.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($44.89 @ OutletPC)
Video Card: Gigabyte - Radeon RX 580 8GB Gaming 8G Video Card ($239.89 @ OutletPC)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case ($55.71 @ Walmart)
Power Supply: SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply ($39.90 @ B&H)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($94.89 @ OutletPC)
Total: $780.15
Generated by PCPartPicker 2018-09-22 17:11 EDT-0400
The i3 is a good match for the 1060, except in games which will need more than 4 threads. Even then you can still play those games, you'll just see framerate drops due to the CPU maxing out here and there. So do a little research into how much CPU your preferred games need, as long as a basic 4 thread quad core is all it needs then the i3 will be enough.
