Firstly, I have read some other threads regards the topic. But, they all seem so specific. So, I have some questions that might help me understand the process.
I currently have a stable OC on my FX 8370 (4.65MHz @ 1.332V). However, during the overclocking process I disabled 'cool and quiet' and I'd now like to turn it back on - There are often long periods of time when my system is on, but idle.
I popped back into the BIOS and enabled 'C&Q', but to no avail. The cores and Voltage still sit at their manual OC settings, not lowering at all, even when CPU usage is 0% for a prolonged period.
1) Why is C&Q not activating despite being enabled? Is this because I am no longer using 'auto' on things such as multiplier, bus and voltage?
2) I have heard that 'offset voltages' are what I am after. Is this correct?
3) I have seen videos where people use software (K10STAT). Is this a good solution?
I think that's enough for now, here are my specs:
FX 8370
M5A99FX Pro 2.0
R9 290
850W PSU
16GB RAM
Here are my OC settings:
TO BE EDITED...
FX 8370
M5A99FX Pro 2.0
R9 290
850W PSU
16GB RAM
TO BE EDITED...
