Please help me and my first build.
Zack Heltz
23
http://pcpartpicker.com/user/zackheltz/saved/mVLbt6
I want to use this case because i already have it because i got it from a store that was closing so i got it for cheaper( i guess i can buy a new one... but i cant return this source 210.) Is there anything i can do inside this case to make a space for the usb port? or for the room for the graphics card. [Edit] if its possible to work this next source 210 to work with my motherboard and graphics. it would be great i dont want to find a home for this case, its brand new not even opened yet
IF there is no way to fix this , i could just buy a new case, could anyone find me a case that works perfectly with my pc part picker from above? It would be cool if it could be white with blue leds with atleast 2 120mm fan spots. I know this post was a run on but i just found this issue out after getting the case and 3 of the parts. So i am a bit flustered.
Also if the case can be around $50..
PCPartPicker part list: http://pcpartpicker.com/p/VDGKkL
Price breakdown by merchant: http://pcpartpicker.com/p/VDGKkL/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($208.99 @ Amazon)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard ($88.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($79.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($48.47 @ OutletPC)
Video Card: Sapphire Radeon R9 280X 3GB Tri-X Video Card ($199.99 @ Newegg)
Case: NZXT Source 210 Window ATX Mid Tower Case ($51.98 @ Newegg)
Power Supply: Corsair CSM 750W 80+ Gold Certified Semi-Modular ATX Power Supply ($79.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD...
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($82.79 @ OutletPC)
Total: $845.18
Generated by PCPartPicker 2014-11-23 08:20 EST-0500
