Please help me check the configuration of my first build
Oct 20, 2018
5
CPU: AMD Ryzen 5 2600X with Wraith Spire
GPU: Gigabyte GeForce GTX 1070 Ti Gaming 8GB
RAM: Corsair Vengeance RGB Pro CMW16GX4M2C3000C15 16GB (2x8GB) DDR4
MotherBoard: MSI B450 Gaming Pro Carbon AC Motherboard
SSD: Samsung 970 EVO M.2 NVMe SSD 250GB
Storage: Seagate Barracuda 2TB ST2000DM006
Case: Cougar Panzer Evo RGB Tempered Glass Full Tower
Power: Corsair RM650x Gold 650W Power Supply
System: Windows 10 pro 64bit
CrazyDingo
156
Your memory - I don't see that on either the AMD Ryzen memory support list or the Corsair Ryzen memory support list (but maybe these lists are out of date or I just didn't see the item on the list):
https://www.amd.com/system/files/2017-06/am4-motherboard-memory-support-list-en_0.pdf
https://www.corsair.com/us/en/ryzen
You may also want to check that the pcie lane usage of the m2_nvme drive is not going to cause you any problems.
5
Thanks for your response. I have decided to change my memory to Corsair Vengeance LPX CMK16GX4M2B3000C15 16GB (2x8GB) DDR4, which should work fine for the build.
