Well, here I am again, calling upon the help of this great
community. In particular, I need advice on choosing a new
case.
I currently have a Rosewill Destroyer http://www.newegg.com/Product/Product.aspx?Item=N82E16811147144]
All things considered, it's not a bad case. In fact, I'd say it's one of the better cases you can get for it's price.
However, the included case fans are noisy, very noisy. At the very least, I'm going to have to look into getting
a fan controller, if not a fan controller + new, quieter fans. I could only plug one into my motherboard, and turning it
down doesn't help much at all. I have 4 total fans (120 mm) in the case.
On top of that, I am seriously thinking about overclocking my core i5 processor. In order to do that, I'm going to need a
good aftermarket cooler. I have narrowed my list down to these two:
Arctic cooling freezer: http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
Cooler Master 212: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
The Rosewill case is only 7.41 inches wide, and I'm concerned that I'm going to have issues fitting any aftermarket
CPU cooler into it.
As far as potential cases go, Newegg has some pretty good deals on right now.
They have the HAF 922 for $89+free shipping with a promo code.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
The Antec 900 is $99+9.99 shipping right now.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
The Antec 902 is $109.99+9.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129058
The Cooler Master Storm Scout is also $99+free shipping+$20 rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196
And this Lian-Li is $99+19 shipping right now:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112239
I'm definitely leaning toward the HAF 922. That seems like a pretty great deal
with the free shipping. If I wind up getting it, would you recommend that I add
a 200mm side fan, or are side fans overrated, as a lot of people seem to think?
All of these look like great cases with great airflow. Pretty much all of them
are about an inch wider than the Rosewill, and the 922 is like 10 inches wide.
It's pretty much a Full Tower. Do any of you have experience with any of these cases,
and if so are there any on this list you would recommend? I'd also be willing to
get a full tower if you think that's the best option, but I wouldn't want to spend
more than $150-60 max. I think newegg has the HAF 932 blue edition for like 149+9.99 shipping
as well. That would be about as much as I'd want to spend.
I should have looked into my case choice a little more thoroughly at the time.
But then again, I wasn't planning on overclocking then.
I'd like to have a case with built in fan control, but if it doesn't have one, I could just order a fan controller.
As far as fan controllers go, this one seems pretty good for about $40 including shipping:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811998038
This Zalman looks okay too, but it doesn't come with adapters. It's about $32 with shipping:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813999251
Are there any other cheaper, equally effective alternatives to these two, if I wind up needing
a fan controller?
Any advice you can offer would be greatly appreciated. I just want to make the best possible move
here and choose a case that will provide great cooling as quietly as possible, while offering good room for expansion and upgrades.
I really should have thought of this before getting the Rosewill, I know. But it seemed like a great deal at the time for $60 and free shippping. It's not a bad case at all.
But I really think I should go ahead and upgrade the case now, instead of regretting it later on.
Or, do you think I should just relax, get a fan controller, and stick with the Rosewill?
Also, am I wrong in thinking that a good aftermarket cooler would have trouble fitting in this case?
case.
CPU cooler into it.
a fan controller?
