[SOLVED] Please help me choose a pc case fan!
Nov 1, 2018
Please help me choose a pc case fan or fan(s). I am getting a phanteks eclipse p300 pc case which will have inside a ryzen 5 2600x, EVGA 1060 6Gb SC, 2x8 G.Skill Aegis ram so it is some heat to blow away.I am not sue how to figure out what fans or fan I need for this case. I am new to pc building and this is the only part In buying I have got stuck on and I am not sure how to pick a fan or fans. Do I need 2 or does that case already come with fans? I'm just not sure. I want decent cooling and I also do not plan on overclocking ever.
Your case comes with 1x120mm as a rear exhaust. You can install 2x120/140mm as front intakes and 1x120/140mm on the top. Depending on how much you want to spend, where you will be purchasing from and what exactly you are after there are plenty of choices. I would personally get 2x140mm as front intake and call it a day.
