Please help me choose a sata 3.0 port!!!
hillelslovak
147
My rig is : http://
I have added two 3tb toshiba internal hard drives, an Amd r9 380x, a Corsair 600w psu, and recently swapped out the motherboard for an Asrock H170M Pro4 motherboard, 16 gb of dual channel G Skill DDR4 2133mhz ram, and an intel i5 6600 processor.
Now, since I upgraded, the front top usb 3.0 hubs have stopped working. I tried every solution I could find online, nothing. Even took the rig to a really good local repair shop. They could do nothing either. I just said screw it, and resigned to just buy another hub to put in my front expansion slot.
So, could you guys recommend a 2 port usb 3.0 hub that I can fit in the 3"5 inch expansion slot in the front of the pc for under 30 bucks?
I have not had any problems with windows 10, or anything else on my pc. Not the other usb ports even. Just the front one. I need help finding a decent usb 3.0 hub with the headphone and hd audio jacks, so I can put it into the expansion bay.
http://
Should that one suffice?
