[SOLVED] Please help me choose my next GPU
spardason
49
Hello, so i currently have a GTX 1060 6 GBs paired with a ryzen 5 2600 and 16 GBs 3000 Mhz, Apparently the ryzen is stronger than the GPU and is causing a bit of bottleneck, so i decided to upgrade just a bit with a GPU from the previous gen, im not rich and the GPUs are very expensive...so i was thinking something like a 1070 GTX or RX 590, right now...which one is better? also, I live in south america and those are...affordable, the new gen, such as the RTX are like 2 or 3 times more expensive, so please don't recommend me those
it wouldn't make sense to spend money on upgrading from 1060 to 1070 or even rx 590. the differences are not worth spending money . i advise you to keep your current 1060 right now it is still a not bad card and wait for the rtx 2060 price to be affordable to you it would make more sense to make such an upgrade than investing money in an upgrade that gives a barely noticeable difference for the money
