Please help me decide what wattage I need for the following system. I used the non-detailed Newegg calculator which suggested 400W and the eXtreme power calculator (http://extreme.outervision.com/PSUEngine) which suggested ~380W (factoring in: overclocking, future SSD, future USB device, wireless NIC, and randomly selected 3 case fans because I don't have a case yet). I don't plan on using Crossfire. Do these wattage suggestions seem low to you? Should I be safe and go with a PSU with a lot higher wattage than suggested? Do these suggestions consider extras such as webcams, flash drives, etc. that will also be plugged in?
I would also appreciate any specific PSU recommendations.
I've already purchased the following components:
Brains: Intel i5-2500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Mobo: Gigabyte Z77-D3H
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128543
RAM:
G.SKILL Ripjaws X Series 8GB (2 x 4GB) DDR3 1600 MHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
GPU:
SAPPHIRE Radeon HD 6850 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
HDD:
Western Digital Caviar Black 1TB 7200 RPM SATA3 64MB cache
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Cooling:
COOLER MASTER Hyper 212 Plus
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Oh, and I have a DVD-RW drive (LG GSA-H10a) harvested from an old computer.
Thanks!
RAM:
GPU:
HDD:
Cooling:
Thanks!
