Hello
Sorry to post yet again about cases but I wouldn't have expected this to be the biggest problem
I require the following:
1. At least front fans, reasonably silent
2. Must not have lights on fans or must be easily turned off. Dumbest idea, this should've been custom not omnipresent
3. Must have mesh over the front fans, or nothing. If no other way, the glass front panel should be easily removed without the use of a hammer preferably
4. Must have at least a 240 mm slot on top to mount my liquid cooling
5. Side panel must be easily removed
6. Under 100 in price, and I've seen plenty around 50, they're just all bad (regardless of price)
7. Top USB / jack slots, and reset/power buttons
8. Amazon will do fine
Thank you
Thank you
