Please help me find a motherboard
May 18, 2018
9
All I need is a motherboard that will support my i7 4790 and 32 gb of ram.
The only one I could find was this
ECS - B85H3-M(1.0) Micro ATX LGA1150 Motherboard
But the reviews scare me. My price range is around 100
32GB of ram is a tall order. That would have been the high end boards. I'm surprised there is a B85 that does.
Next closest would be the ASRock H97M. After that you are looking at the used market.
Check out the Asus Z97-A:
https://www.asus.com/Motherboards/Z97A/
Socket LGA 1150 (for 4th gen chips)
32GB DDR3 RAM support, up to 3200MHz if you overclock
Edit: Now I see that your price range is about 100$ and this mobo is about 200$
