Please help me guys.
galnagunnar63
9
Hi have just finished building my first computer but when i start it the fans, cpu fan and psu work but nothing is displayed on the screen... And there is a red led thats shines in a red color. Under the led it says ''DRAM_LED''. I have tried switching the ram memories and tested with just one but nothing will work... Please help me!
Motherboard: m5a97 R2.0
galnagunnar63
9
There is only one four digit number on the board and that is 1302.
galnagunnar63
9
I have tried doing that now and the red led still flashes at startup.
galnagunnar63
9
When i press the MEMOK! button for 3 secs it flashed and then the red light disapperas. Nothing will happen on the screen though. But when i restart the motherboard the red DRAM_LED still flashes.
galnagunnar63
9
It is the same with 1 stick in any slot and i have tried it with both sticks. I dont know if there is a backplate for the cpu fan.
What CPU fan using?
At this point I see these options:
-try clearing the CMOS (unplug the power cord and remove the CMOS battery for few minutes) If still the same,
-try using the flashback for flashing the BIOS with the latest version (make sure you rename the downloaded and unzipped file from ASUS - check the manual for the name, use a FAT formatted USB stick and insert it in the Flashback USB port)
-if still the same, borrow a RAM stick and test
-try also reseating the CPU.
If still no go, I would RMA the board and the CPU.
