I have spent about 500 dollars trying to figure out why my computer is not working properly.
I called AMD the other day and they told me the reason my screen kept going black is because my GPU was dying. So I bought a R9 390x to replace my R9 280x. Same problem occurred. So I assumed it was a power issue, so I bought a new PSU... nothing it kept doing the same thing. I then think it's a problem with my motherboard, I end up removing my graphics card and hook up my DVI to the motherboard integrated graphics, it works perfectly. Then the final thing I did was uninstall the video drivers... the computer now works fine. Problem is it only works without the amd video drivers installed. Right now I have everything hooked up and is working perfectly, just looks ugly.
Symptoms I have discovered. Right before/after the AMD video drivers are installed the following happens
-Screen goes black.
-GPU fans stop spinning.
-GPU starts to heat up.
Same thing with the 280x.
My computer specs
gigabyte Z97x gaming 3
Intel i5-4670k
16gb Ram
SSD 250gb
HDD 1TB
R9 390x or 280x.
Windows 10 pro
Help me solve this please. Ask for any further info please. Bios is up to date.
-Screen goes black.
My computer specs
Intel i5-4670k
16gb Ram
SSD 250gb
HDD 1TB
R9 390x or 280x.
Windows 10 pro
