Hello!
So I am trying to upgrade an old windows 98 pc to windows xp and I am having a terrible time trying to do so. I have hareware checked and am compatible with the windows xp OS. My problem is that I can not get any data in or out of this pc. It currently runs Windows 98 second edition. I have a cd-rom drive that continues to say that the drive is not accessible. I need a driver to update it. I can not connect to the internet in any way. I have an outdated internet explorer that I can not get the security options configured correctly to allow me to connect to anything. I have successfully updated from a dial-up to an ethernet ISA card. Drivers have downloaded successfully. I have a floppy drive that works just fine. I have usb ports that are only working for the mouse and keyboard. My thought was to install the ethernet card, connect to the internet, and update my usb driver to be able to insert a bootable flash drive with the windows xp OS. The current state of my usb drive does not allow data transfer. I have even gone as far as buying a floppy disk writer to move the drivers from my newer pc to the older pc. This is the only method I have been able to use to get data to the windows 98 pc. However, I can not get the drivers to run or install. I also do not know exactly how to do this. But when I move the driver installation there is no detected program to run it. I have also tried to do a Lan connection to the pc from my newer pc, and although I get it to work, when I tried to download the XP OS files to my newer pc and then to the 98 pc this way, there are some files that I can not see on the windows 98 pc and it ends up corrupting the install. I am stuck and need help. I just want to be able to insert the bootable flash drive and install windows XP, with no internet, no cd-rom, no usb port that will recognize a usb drive. Ideally if there is a way to get a proper driver on a floppy disk and directly install it from the floppy to allow me to insert and recognize the usb stick is the route I keep coming back to. Any recommendations would be greatly appreciated. I have tried and used a few version of nusb36 e and other drivers but it keeps telling me that it is looking for a newer version of windows and cancels. Someone please help me troubleshoot this.
