Hello everyone!
I am not sure if this is the right section, but here it goes..
I have an Acer Aspire X3960. It comes in a really small case...
And I would like to buy another case (a big one), because I would like to upgrade my graphics card, but it doesn't fit in this one.
I would like to know if my motherboard etc is compatible with bigger cases, and if so, which ones? Or are cases all-round?
My specs..
CPU:
Mainboard:
Memory:
SPD:
Current graphics card:
I would like to upgrade to maybe a GTX740 2GB DDR5 or a GTX750 1GB DDR5.
Also, if I am able to swap cases with my current setup, which of these 2 cards would be better with my current setup (including power supply), if the powersupply isn't good enough, how much watt and maybe which one would you advice to me for a really low-budget?
Thanks in advance! <3
Nathan
My specs..
CPU:
Nathan
