Please help me pick fittings I should use for my custom water cooling loop
Jordan08041997
112
I don't want you to pick a brand or whatever but I just need to know how many different fittings and what angles I will need to use for my Setup I'll be using 1 gpu block and 1 cpu block a 420mm radiator and a 360mm radiator inside the Phanteks Enthoo Primo case but I am really confused with fittings so please help me chose them
No one will really know what angle fittings you will need because we don't know what clearances you have and where. Ultimately you need 2 fittings for each radiator, block, etc...one for inlet, one for outlet.
I would suggest doing additional reading on watercooling as this question is pretty self explanatory once you know what you're building.
