Hello friends, I am deep disoriented about what I should upgrade and not, keep parts, etc...
What I have:
- AMD Phenom II X4 965 at stock. I tried to overclock it in all the ways I know, multiplier, multiplier + NB multiplier, front bus, etc... to 3,8 3,9 and 4,0. No luck, I get BSODS and freezes at any voltage setting. Either my PSU is holding me back or the motherboard is unable to OC. Therefore I had a frustrating experience with OC at all.
- CPU Cooler: CoolerMaster Seidon 120M. I bought it because I wanted to overclock the phenom, but even keeping it under 60 celsius on load, I get the above issues. I am not sure If I should keep it or get its big brother, the Seidon 240. Worth it?
- Motherboard: The cheapest one I found when I built my computer, because I was on a budget. Currently an ASRock 960GM-GS3 FX.
- GPU: I got a nice and cheap Sapphire Radeon HD 7770 Vapor-X that is OCed from factory. I was able to run source games, Battlefield, RO2, etc all in high graphics and 1080. But all people says is weak 🙁 so i am not sure to keep it, get a second one and crossfire or totally replace it.
- Hard disk drive: This is totally out of question. I had to get a laptop 5400rpm 465GB Hitachi that is clearly bottlenecking me...
- Memory: I have two kingston modules, 4 gb each. I can overclock them from 1333 to 1600. My brother have 4 modules of 2gb each, elpida 1333, that I could exchange with him just if needed.
- PSU: I am currently using a generic, white OEM 500w unit, with two sata connectors, two 4pin connectors and the two cpu/atx ones. This is what I am not sure to do. In my backroom I have a Sharkoon WPM 600W which is way way more decent (80 efficiency, lots of cables). So I should use this in the upgrade or get a more powerful one?
- Others: I have a Xonar DG audio card, a spare Core i7 3820 that I do not know if still functional or what (x79 motherboards are too much priced, i couldn't test it), a generic CD reader, generic card reader, and a 21,5 1080 LCD monitor.
What I want to do with my PC? Light gaming, most of it Source engine, occasional adventures into COD and BF world, etc and also record with fraps and edit with vegas and encode it with several edition and rendering tools. I plan to ocassionally mine, or contribute to folding@home.
My budget to upgrade is max 410 € (557 Dollar). I have think getting i7 4470, FX 8350, Core i5, etc...
ANY suggestion or idea will help me to decide what to do, and I will appreciate it. Thanks.
What I have:
