Currently I am only running 2gb of RAM in my computer, as 1 of the sticks is being sent back to g.skill to be replaced under warranty (it is shot). So I only have one stick of RAM in my computer atm and I obviously need more...the RAM will be doubled to 4gb total when my other stick is replaced...but my question is this. I currently only have one stick of RAM in so where should it be? My mobo has a total of four slots blue, black, blue, black...when I ran two sticks of RAM I had both sticks in the blue slots... cradles 1 and 3...as I assume this is dual channel correct?
I am currently shopping around as I want to increase my RAM from 4gb up to 12gb most likely...can I run a total of 4 sticks of RAM successfully and at their full capabilities? I assume I would set it up as follows... 2gb stick, 4gb stick, 2gb stick, 4gb stick from left to right. So that the sets of RAM are in the same color slots... I hope this doesn't sound too confusing. Basically I'm currently at 2gb (which cradle should this single stick be in?) but when g.skill is done replacing my old stick Ill be up to 4gb but am looking to add about 8gb more after that for a total of 12gb. Can I run 2x2gb and 2x4gb with perfect stability? And if so do they all have to be the same brand etc?
My mother board: Here
G.Skill Ripjaw DDR3-1600
