• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Meet Stan Dmitriev of SurrogateTV on the Pi Cast TODAY! The show is live August 11th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Professional PC modder Mike Petereyns joins Scharon on the Tom's Hardware Show live on Thursday, August 13th at 3:00 pm ET (8:00 PM BST). Click here!
Question Please help me with choosing the right setup.
Apr 17, 2020
Hello,
I would really appreciate your help with the needed PC parts. I am building my first PC and I am utterly lost. I only got this far thanks to my friend that knows little but more about PCs. The PC would need to be powerful enough for games like Assassin's Creed: Origins, AC: Syndicate, ARK Survival Evolved, Elder Scrolls V: Skyrim, ES: Online and so on together with being able to handle graphic programs including 3D. I currently have MSI Gt72 6qe laptop, Intel Core i7 -6820HK CPU, 16Gb RAM, NVIDIA GeForce GTX 980M and while it is doing quite fine there are some problems while playing (especially ARK and AC: Syndicate) and working on some 3D projects. So after deciding to upgrade to PC (the poor laptop is dying) I would also like to upgrade my gaming experience.
With the help of the friend and some of my own research I came up with 2 almost complete setups and one that has several different combinations of parts I am considering which I made without help. If nothing else the first two setups should be compatible and functional but I am not sure about the last one. So I would like to ask for a help with choosing the setup and parts or even suggesting some alternatives (bear in mid that in the country I am from some parts are not available so some suggestions may not be a possibility for me but I would still appreciate them).
What I am looking for in the setup:
Good for some more needy games and graphic programs, minimum of 2 HDD slots, minimum of 240GB SSD ( I would prefer more HDD space than SSD since SSDs are more expensive and I always run out of space due to the large space requirements some games need and I am fine with waiting longer for games to load, I would only need the SSD for the OS and some online games), 3TB HDD, 2 monitors. As for the price it is hard to tell since the parts here have different prices and because of the currency conversion but I am looking for something that costs between 1000 to 1500 euros.
SETUP 1
CPU: Intel Core i7-9700K
CPU Cooler: ARCTIC Freezer 34 eSports DUO
Motherboard: ?
Memory: Crucial 16 GB DDR4 2666 MHz CL19 Dual Ranked or Kingston HyperX 16GB DDR4 2666 MHz CL16 FURY series
SSD: WD Green 3D NAND SSD 240 GB M.2 or ADATA Ultimate SU650 SSD 240 GB
HDD: Seagate BarraCuda 3 TB or WD Blue 3TB
Video Card: MSI GeForce GTX 1660 GAMING X 6G
Power Supply: EVGA 650 BQ
Cases:
Corsair Carbide Series SPEC-DELTA RGB Tempered Glass
SilentiumPC Signum SG1X TG RGB
SilentiumPC Regnum RG4TF RGB Frosty White
SilentiumPC Signum SG1V EVO TG ARGB
MSI MAG VAMPIRIC 010M
Zalman K1
Phanteks Eclipse P360x Tempered
SETUP 2
CPU: AMD RYZEN 7 3700X
Motherboard: ASROCK B450 Pro4
Video Card: AMD Radeon RX 5700 XT 50th Anniversary (the most expensive out of all the ones I am considering)
Cases:
Zalman K1
SETUP 3
(supposedly AMD and NVIDIA components can be mixed)
CPU: AMD RYZEN 7 3700X or Intel Core i7-9700K
Motherboard: ASROCK Z390 PHANTOM GAMING 4 or ASROCK Z390M Pro4
Video Card: (from the cheapest to the most expensive)
MSI Radeon RX 5500 XT GAMING X 8G
GIGABYTE GeForce RTX 2060 OC 6G
XFX Radeon RX 5700 XT THICC II Ultra 8G
Power Supply: EVGA 650 BQ or Seasonic Focus GX 750 W Gold
Cases:
Zalman K1
____
I also found some pre-built setups and am considering them but I have no idea If they are approximately as good as the other setups for similar If not lower price. Plus all but one lack any HDD so that is another 90 euros for one.
SETUP 4
CPU: Intel Core i7-9700F
Motherboard: GIGABYTE B365 M AORUS ELITE
Memory: Corsair 16 GB KIT DDR4 2666 MHz CL16 Vengeance LPX
SSD: Corsair Force Series MP510 960GB
HDD: None (will need to buy one)
Video Card: GIGABYTE GeForce RTX 2060 OC 6G
Power Supply: GIGABYTE P650B
Case: Corsair iCUE 220T RGB Tempered Glass
OS: Windows 10 Home 64-bit
SETUP 5
CPU Cooler: Cooler Master Hyper 212 LED
Motherboard: GIGABYTE B360M AORUS Gaming 3
Memory: HyperX 16 GB KIT DDR4 2666 MHz CL16 Fury Black Series
SSD: WD Blue SN500 NVMe SSD 500 GB
HDD: WD Blue 3TB
Video Card: GIGABYTE GeForce RTX 2060 SUPER WINDFORCE OC 8G
Power Supply: Seasonic Focus 650 Gold Semi-modular
Case: Fractal Design Meshify C Mini Dark TG
SETUP 5
Motherboard: MSI B360M MORTAR
SSD: Corsair Force Series MP510 1920GB
Power Supply: GIGABYTE G750H
Case: NZXT H510 white
SETUP 6
Motherboard: GIGABYTE B450 AORUS ELITE
Memory: Corsair 16GB KIT DDR4 3200MHz CL16 Vengeance LPX
Video Card: GIGABYTE Radeon RX 5700 XT GAMING OC 8G
__
Some additional help would also be appreciated with choosing the Monitor and Keyboard.
As for the keyboard I have no idea which keyboard to get. All I want from it is to be quiet and have backlights.
MONITORS
23"-25", probably IPS, Full HD, 1920×1080 px, 16:9, not curved frame, flicker-free, blue light filter ? ( Ialready have blue light filter glasses so not sure If I need the screen to have it as well), built-in speakers would be nice since I cannot use headphones for long and the speakers I have at home, while good, are massive and I do not have enough room for them to use them permanently.
Samsung LED C24F396 23,5"
AOC 24G2U5 Gaming 24"
Dell P2419H Professional 23,8"
While I want to use two monitors right now I will be getting only 1 and for the second one I will be using my old LG FLATRON IPS225 which should be compatible (connects via HDMI). I will get the second one at the later date.
As I am mostly considering the AOC 24G2U5 Gaming 24" which has Freesync I guess it would be preferable to be able to use it which, If I am correct, I would need specific GPU.
OS
All the setups will also need OS. I will get either Windows 10 Home 64-bit or Windows 10 Pro 64-bit. I have Home right now so I am not sure If I need upgrade to Pro.
