I want to buy a new PC. I want to be able to play fairly recent games at medium settings such as World of Tanks, GTA 5 and Fifa 16/17, I'm not obsessed with graphics as I tend to prefer slightly older games, nor am I looking for super high frame rates However, I definitely want to be able to upgrade later, especially in terms of the GPU if the prices ever return to normal Earth-economy levels.
Here are the specs my vendor has suggested, and I would be greatly appreciative if anyone can give me some pointers on the general compatibility of these parts in relation to my stated goals.
AMD AM4 RYZEN5 2600
AM4 ASUS PRIME B350M-K
DDR4/2400 KINGSTON HYPER-X
COUGAR 650W STX650 (80+ WHITE)
SAMSUNG SMEX2220 MONITOR - already owned
120 GB SSD GALAX GAMER L
Note no GPU yet in this particular build. I was hoping to either put an old GTS 450 that I already have in myself or find a mid range card if necessary. I am concerned that after buying the parts, I won't be able to play any games or see anything.
1. Will it be possible to connect this board to my monitor, as I have heard rumours that the board and or the CPU doesn't support VGA? I am not sure what HDMI or the other one means, and I don't own a TV anyway.
2. Will I be able to plug my GTS 450 into the PCI slot and or any other cards I will buy in the future?
3. Will the onboard motherboard graphics be any good for gaming, at least in the short term?
Thank you kindly in advance for any advice you can give me.
AMD AM4 RYZEN5 2600
