Please Help me with Corsair H100i Gtx
tahnik
163
I am using the link software right now. There is always this noise coming out of the cooler. I didn't understand till now but when I change pump power the noise doesn't change. But when I set the fan to quiet mode the whining noise becomes much more tolerable.
Should I change the fan? Is the problem with fan or the pump?
Thanks
It is coil whine from the fans. Unplug one of fans and test to find out which fan is causing the issue, then replace it. Corsair might supply you a replacement fan, but I'm not an expert on their warranty services. You should look into it though.
