Please help me with mobo connections!
Zombie_1
Commendable
May 17, 2016
48
Hi, I just got a new mobo and cpu, im trying to start the pc but the power button led wont light up and the pc does not start. I think I may be putting the pc power , usb ect. connectors in wrong, any help would be appreciated, thanks.
links to pc connectors i need to plug in and the mobo :
http://i.imgur.com/AOSsZH8.jpg
http://i.imgur.com/QIIHeb1.jpg
there are no letters on the cables , im hoping someone can tell what they're each for and where they go by looking at the number of holes they each have ect,.
All of them not labeled Audio or USB, not that hard to figure out, right? If you're not sure what cables are what just see where they lead in your case, if it leads to the Power Button it's you guessed it probably the wire for the power button. If you're not sure which side is +/- There's a small arrow on the end cable not the pins. If you need more info Google it takes like 5-mins and has been answered more than once.
I shorted out the pins and all the fans started but the monitor says "no signal"
I know where all the connectors go now but when i press the power button nothing happens i have to short it to start it and even then the monitor says "no signal" I dont know whats wrong
