I've searched around and haven't found a solution to my problem.
I just upgrades my HD 6870 to an R9 390 (MSI 8GB 512-bit with the twin frozn cooler & cooling backplate).
I play WoW (no other games to test unfortunately) and thought I could jam on ultra settings since I absolutely should be able to. Unfortunately, I'm sitting around 40 fps in 25m raids and I will bounce from 90-100 fps out by myself down to 40 fps very often.
Playing on 2560x1080 ultrawide monitor.
I did a DDU driver complete uninstall then downloaded and installed the latest AMD Crimson driver.
I ran Furmark at 2560x1080 with dynamic background, burn-in, xtreme burn-in, and post-fx all enabled - I saw a constant 40 fps over 7 minutes of testing, temperature was completely stable at 78°C and the fan wasn't even running more than 75%. So my GPU seems to check out fine, albeit this was only a 7 minute test.
When I'm playing WoW and running MSI afterburner, my core clock jumps up to the posted 1040Mhz but also jumps down to ~300-350 Mhz often. Also, my GPU usage spikes around a lot and doesn't really go over ~50%, and since it spikes all over the place, let's just say the "average" gpu usage is around ~25% but pretty much jumps between 10% and 45%. CPU load never goes over ~40%. All temperatures are very cool.
My monitor is 75 Hz but I have it set to 75 Hz in WoW with vsync disabled.
Monitor "freesync" is disabled also.
I have the monitor hooked up via displayport cable.
System:
Phenom II x4 965 black 3.4Ghz stock clock (no OC)
Hyper 212 Evo cooler for CPU
ASRock 970 EXTREME3 AM3+ AMD 970 + SB950 5 x SATA 6Gb/s USB 3.0 ATX AMD Motherboard
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
MSI Radeon R9 390 DirectX 12 R9 390 GAMING 8GB 512-Bit GDDR5 PCI Express 3.0
Mushkin Enhanced ECO2 2.5" 240GB SATA III MLC SSD
Windows 10 64-bit
Rosewill RBR1000-MS 1000W Active PFC PSU - Continuous @ 104 Deg. F (40C)
I feel like my machine should be MORE than capable of handling WoW at full settings without any stuttering (which it's also currently doing).
My are my CPU usage, GPU usage, and temps so low and why don't they try harder to up my FPS when gaming? The GPU fan barely even kicks on because the temps are so low to begin with (low GPU load). Even though I'm playing at a higher resolution 2560x1080, I have more than enough vram to handle it now (8GB). I drop down to ~15 fps at times when walking around a crowded city too, which is annoying. Even my old HD 6870 didn't do that.
Please help!
System:
Windows 10 64-bit
Please help!
