Hi guys, i just bout a power supply which's a 400 watts by cooler master to replace my old dell one which is 244 watts and i have a new video card also nvidia gtx 650ti 2gb anyways when i installed the power supply and pressed power, the cpu and pc fans span then right after that it stopped and the power supply started making loud clicking noise but no smoke/burning smell came out of the power supply,when i looked at the back of the power supply the voltage switch was on 115 is't possible that the psu is on wrong voltage ? there is another option on the voltage switch with is higher, if i changed the voltage switch would my psu work fine or should i change the psu for another one ? thanks for anyone who helps
