Please help me with some feedback or suggestions about this system.
Nick95
5
Hello!
So I started building my first gaming PC but I need some feedback and opinion/suggestion about it before I step to purchasing the components.Here's what I would like it to look like so far at least!
CPU: Intel Core i7-3770K 3.50GHz Socket LGA1155
CPU Cooler: Corsair Hydro H60 Liquid CPU Cooler
Motherboard: ASRock Z77 Extreme4 socket 1155
Memory: DDR3 1866MHz 2x8GB Vengeance CL9 1.5V
Storage: 2x 1TB Western Digital WD Caviar Black, 64MB cache, 7200rpm, SATAIII-600
Video Card: ASUS GTX770-DC2OC-2GD5
Case: Cooler Master Elite 430 Black
Power Supply: 750W Corsair CMPSU-750CX
I'm looking forward to any recommendations, thanks a lot!
Oh, well, I don't think so I don't use Adope Photoshop or similar heavy programs at all. I don't have any past experience with building a system. No it's not pre-built. I'm going to build it myself. I'm looking for all kind of suggestions. Would that motherboard go neat with the listed components, is the certain computer case appropriate or should I invest some more cash into buying a better one? :)
Well, you don't really need an i7, the i5 would suffice. The motherboard is fine. You want a better quality power supply. Corsair CX series aren't great. Not sure of your prices at your location, but see if you can fit a Haswell build. It should be at a similar price but Ivy bridge cpus are still fine. Not sure on the h60 , the cooler master 212 EVo will do the same job at a cheaper price.
Look for Seasonic or XFX power supplies. 550W for GTX 770 build is fine including overclocking. Maybe consider a SSD for a snappy OS and faster boot times.
Thank you sir! :)
