Please Help Me!!!
Albayrak
103
hello guys i was about to get the nvidia evga gtx 750ti superclocked then someone said the gtx660 is better so now i am going for the 660gtx superclocked this is the graphics card http://www.ebay.co.uk/itm/EVGA-NVIDIA-GeForce-GTX660-Superclocked-2GB-GDDR5-HDMI-Video-Card-02G-P4-2662-KR-/170911507918?pt=PCC_Video_TV_Cards&hash=item27cb1ea5ce and this is the psu that i got http://www.ebay.co.uk/itm/NEW-SILENT-500-Watt-ATX-PC-Power-Supply-Unit-PSU-500W-/370336642035?pt=UK_Computing_PowerSupplies_EH&hash=item5639c8b3f3 would i be fine the only games i want to play without lag is DayZ Minecraft Cod4 and Counter strike please let me know which one is the best for me
Just to further emphasize trawet's point:
A lot of people think that they can shave a bit off their budget by going with a cheap power supply... After all, its not one of the fancy components like a GPU or CPU that is doing the heavy lifting!
However, this is WRONG! A cheap power supply can cause power surges that will damage your components, and potentially destroy that shiny expensive GPU you just bought. In addition, some of the cheap brand power supplies don't even output the wattage they claim. This means that while you might only need 450W, a cheap 500W power supply may only output 400W, and not be able to run your system. I would suggest a power supply such as this Seasonic...
The 660 will out-perform the 750Ti. GeForce's website states that the 660 requires a minimum of a 450W PSU, so 500W is fine but I definitely would NOT get the power supply you've listed. It looks like cheap crap and the PSU can be the most important part of your system!!!
However, this is WRONG! A cheap power supply can cause power surges that will damage your components, and potentially destroy that shiny expensive GPU you just bought. In addition, some of the cheap brand power supplies don't even output the wattage they claim. This means that while you might only need 450W, a cheap 500W power supply may only output 400W, and not be able to run your system. I would suggest a power supply such as this Seasonic: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151094
Also, OP: Please use proper grammar, capitalization, and punctuation when are posting. It makes things much easier and more enjoyable for everybody else to read, and increases the chances that somebody will respond. It will also help to make a more informative title. For example: "GTX 660 or GTX 650Ti for DayZ?" rather then "Please Help Me!!!" (Exclamation points never help.)
edit: typo
