Just received a window R5. There seems to be a couple of issues with it - the window side panel is warped (the window itself), making it very difficult to close it properly. There is a small gap between the window edge and the white panel; is this common? The middle latch for the latching mehanism for the side panel doesn't protrude out as far as it should be to catch the notch of the panel.
Thanks!
Thanks!
