Hello guys and girls unfortunately I am having an issue with my gaming pc ( sorry if this is in the wrong section I don't know where it should go )
So...
Every now and again ( 6-7 out of 10 times ) when I go to shutdown I get a window pop up it says
-------------------------------------------------winlogon.exe - Application Error
The exception unknown software exception (0xc0000008) occurred in the application at location 0x00007FFED9D88C6A.
Click on OK to terminate the program
The window is flickering as if it is trying to close but being reopened straight away ( if you know what I mean )
If I click " OK " sometimes the window goes away And then my pc just hangs trying to shutdown or it will take me to the login screen and if I click power symbol and select shutdown it will just hang while the little dots are spinning in a circle, I have left it over night only to come back and see it STILL trying to shutdown 🙁
Everything on my pc seems to work perfectly fine except when shutting down.
I am willing to try pretty much anything ( hopefully not have to do clean install of windows )
ANY HELP WILL BE APPRECIATED BIG TIME
PC SPECS:
OS- Windows 10 Pro
GPU - gtx1070 8gb Asus strix
CPU - i7 6700k 4.0GHz
MotherBoard - Gigabyte GA-Z170x-Gaming 7
RAM- corsair vengeance LPX 16gb (2x8gb) DDR4 3000MHz
Main Drive - Intel 540s 1TB SATA III
2nd Drive - Seagate ST2000 2TB SATA 3
PSU- Cooler Master V650 650W 80+ Gold fully modular
So...
PC SPECS:
OS- Windows 10 Pro
