M mohitmayank530 May 25, 2018 2 0 10 May 25, 2018 #1 Can I play assassin creed origin with Core2duo 2.6ghz 2gb nvidia GT 710 4gb ram
Solution herrwizo May 25, 2018 Every single component in your rig is at least several times slower than minimum requirements for that game are, so no. You will need a new build.
justin.m.beauvais Estimable Dec 15, 2017 1,525 197 3,840 May 25, 2018 #2 No. Under no circumstances will your system provide a playable experience. I doubt it would even launch. For minimum requirements see: https://www.pcgamer.com/assassins-creed-origins-system-requirements-revealed/ Upvote 1 Downvote
herrwizo Illustrious Feb 17, 2009 5,158 45 40,240 May 25, 2018 Solution #3 Every single component in your rig is at least several times slower than minimum requirements for that game are, so no. You will need a new build. Upvote 0 Downvote Solution
