please help!!my core2 duo processor does not boot in d945GC
rscam97
Hi
I have a D945GCCR chipset with the intel pentium 4 641. I am trying to upgrade it with a core 2 duo 2.66 Ghz processor. When I boot nothing happens, no sound no lights. I also upgraded the bios to the latest version 5/22/07. Please help. What do I do?
thanks
Hi
thanks
You should check your MB manufacturers website to see if your 945 board supports C2D processors. Not all 945 chipsets support C2D. Most manufacturers, including ASUS, released revision 2 945 boards with updated voltage regulators that supported C2D.
rscam97
I checked the intel website and it says this chipset does support the
Core 2 duo's upto 2.2Ghz, but mine is 2.66 Ghz. Shouldnt it work at least at 2.2Ghz or atleast boot and show an error. i dont get any beeps or any sign other than the fan spinning.
what do I do?
what do I do?
You have to check your motherboard's website. I have an ASUS P5LD2-VM 945G and it will not support C2D processors. However, the ASUS website says my board does provided it is a REV 2
My P5LD2-VM 945G is a revision 1. It does not support C2D processors. I suggest you email tech support at your MB or system mfg. and ask if you MB supports C2D processors.
You can try reinstaling your processor. It is rare that a processor is dead out of the box.
dezonio2
29
what do I do?
as badge showed that processor won't work. period. it could be because of FSB on 6 series C2D vs. 4 series. I'd ditch the mobo.
