Hey guys! I'm building my first computer and the one i'm currently using is a P4 3.2ghz with ATi 9200 AGP and 1.5 gig of ram. which i've used since 2004. and now it's time for an upgrade. Here is a list that I need your critique on. The one that is non-bold is what i've already purchased and the one bolded is what I'm planning on purchasing. I need you guys to see if the one in bold is a great choice or poor choice.
How's the vid card choice? keep this or get the sapphire ATi 4870
Is the ram good enough?
How's this motherboard?
What is your thought on this overall build?
thank you!
Motherboard: asus p6t----- http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
CPU: intel i7 920--- http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Video Card: EVGA GTX 260----- http://www.newegg.com/Product/Product.aspx?Item=N82E16814130433
RAM: Corsair xms 6 gig---- http://www.newegg.com/Product/Product.aspx?Item=N82E16820145220
Case: Cooler Master HAF 932
PSU: Corsair 620 watt modular
HDD: WD caviar blue 320gig 16mb cache
Optical Drive: sony optiarc cd/dvd-rw
Monitor: Asus 21.5....2ms response time
Keyboard: logitech
Mouse: logitech g5
OS: vista 64bit
budget on the bolded: keep it under $843.16
thank you!
Keyboard: logitech
Mouse: logitech g5
OS: vista 64bit
