Question [PLEASE HELP] MY PC IS REBOOTING WITHOUT WARNING .kernel power event ID 41
Oct 27, 2019
12
its been a while my pc is getting shut down without any warning please help
it says on event id that
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
-System
-Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331c3b3a-2005-44c2-ac5e-77220c37d6b4}
EventID41
Version6
Level1
Task63
Opcode0
Keywords0x8000400000000002
-TimeCreated
[ SystemTime] 2019-10-27T14:08:21.575072500Z
EventRecordID4889
Correlation
-Execution
[ ProcessID] 4
[ ThreadID] 8
ChannelSystem
ComputerD3VIL
-Security
[ UserID] S-1-5-18
-EventData
BugcheckCode0
BugcheckParameter10x0
BugcheckParameter20x0
BugcheckParameter30x0
BugcheckParameter40x0
SleepInProgress0
PowerButtonTimestamp0
BootAppStatus0
Checkpoint0
ConnectedStandbyInProgressfalse
SystemSleepTransitionsToOn0
CsEntryScenarioInstanceId0
BugcheckInfoFromEFIfalse
CheckpointStatus0
DSzymborski
Glorious
Still need your exact PSU and ideally, a better description of the circumstances leading up to the problem.
And don't bump your thread. This isn't customer service; if everyone bumped their threads in 40 minutes, the forum would be nothing but thread bumps.
Oct 27, 2019
12
it happens randomly doesnot matter if i play games or its idling it just happens randomly
Oct 27, 2019
12
we name name and model of psu also use occt to stress test psu for about 10 min take note of voltage readins before and on test you could also use hwinfo on the sensor page and report all voltages readings from it .
everything seems normal bro i have tested it for 11 mins no error found :/
Karadjgne
Herald
Seriously doubt it's a hardware issue. Almost all occurances of the 0x8000400000000002 - 63 error are directly related to Windows 10 itself after some updates. Common fixes include changing the Power plan in windows, setting HDD to never shut down, changing what the power button does, changing fast-boot options, changing sleep settings or even a full clean reinstall of windows etc. It's basically a glitch in some windows installs where windows decides to try and go into low power mode, while the pc is in active use, and shortchanges the voltages to the cpu.
Oct 27, 2019
12
did you just try another motherboard or how did you find out that it was the motherboard? Im having the same issue
Yeah i checked everything one by one i tested rams i stress tested both cpu and gpu etc in your case it could be power supply so
Reactions: mogv
