[SOLVED] Please help my pc won’t start
Oct 23, 2018
18
Okay so I have this computer and I pulled all the stuff out cause it essentially was not working it will not post that’s it it would be great if you could help me
winks42
Respectable
#1 is everything plugged in on the mobo, 24 ATX pin, CPU power plug.#2 are the front io pins seated in correctly #3 does the system start? If so any lights or beeps? #4 is the psu switch on#5 reset CMOS #6 is a display cable in your gpu(or mobo if you are using intel without a gpu)
Oct 23, 2018
18
Yes yes all the stuff is in it just starts up and does nothing all the fans spin but it just does nothin its not my monitor or cable cause ive tried many
Oh and there is a blue light above my cpu but i think thats normal and how do i reset the cmos
