After I installed windows 7 on my pc and got my antivirus programs up and running,... I went to go check out game performance. So i downloaded Planet side 2 and played it with almost everything maxed out. After 20 minutes of playing this game,... My PC shutdown and won't start back up. I had the pc professionaly wired and put together.
When trying to turn it on, The LED lights turn on and the fan on the heatsink for the cpu runs when i try to turn it on. But nothings apearing on my screen. Its not even loading up to the bios screen. I switched gpus and that didnt help. Oh and when i try to turn it off after turning it on, it wont turn off, i held down on the power button and the pc wouldnt turn it off. To turn it off I would need to flip the switch that has an (I O) thing on it. Idk what it could be, the Led lights on the Mobo light up when i press the on button. But the pc still isnt running.
Is it possible my psu is bad? It's an atx 480 psu that came with my case.
Specs: FX 4130 cpu
gpu. HD 7770 factorty overclocked
atx 480 watt psu
6 gigs of ram 1600 mghz (one stick is a 1333 mhz 2 gigs i scrapped from my old pc.
Note* I had no case fan installed, But it was only 20 minutes of gameplay. and my case has 2 huge vents on the side of the case, so i believe the hot air had a way out. .
Any suggestions?
Specs: FX 4130 cpu
atx 480 watt psu
Any suggestions?
