PLEASE HELP NO DEVICE DRIVERS WERE found
Ediz__
Commendable
Aug 2, 2016
6
I built a new gaming pc, and my PC keeps saying "No device drivers were found. Make sure that the installation media contains the correct drivers, and then click ok" I did everything on the internet, but nothing works. Is it a motherboard problem? Please help. Thanks
Hi,
Your motherboard will have come with a disc, please insert the disc into your optical drive if you have one on your computer in order to install the motherboard's drivers.
After that, use the disc from the Graphics Card to install the drivers, I do not recommend going straight to the internet for device drivers if you have got new parts, mainly because if you are new to computer gaming/building you may use the wrong website/drivers.
what do you mean.
Hi,
okay, ill try that. brb
