Please help!No sound!
K0kY
39
Hello guys,
I have gigabyte p35-ds3l.I installed windows 10 64bit on it and i have no sound,I tried installing all possible drivers i could find but none of them works
You do realize that the latest audio drivers for your board are for Windows 7, right? While that may work, I can't guarantee it.
Your best option would probably be to spend like $10 and get a USB sound card. I mean, even the cheap stuff will sound better than the onboard audio on such an old board. You'll still need to have speakers, of course.
What drivers did you install? Try http://www.realtek.com/downloads/ (High Definition Audio Codecs). Also, try making sure the volume knobs on whatever you're using, aren't muted or all the way down.
I installed drivers i found on driver scape for audio, I tried chipset drivers.When I go to device manager I see some 'PCI Simple Communication' driver missing.
1) The REALTEK link should be correct (v2.82 and 250MB or so is the correct one for 64-bit)
Though you should still have basic audio already after W10 installs.
2) Did you confirm the SPEAKERS work with another computer or device?
3) if unsure on speakers, try other speakers or headphones
4) STEREO speakers should use the GREEN, stereo output from the motherboard (may be a different color)
5) right-click the audio icon and select "playback devices" to ensure that the REALTEK is selected (assuming you use the Realtek output from the motherboard)
6) make sure AUDIO is not disabled in the motherboard BIOS (usually boot into with "F2" on system boot)
7) if all that fails you'll need a PCI, PCIe, or USB device to add sound (or if the monitor has speakers or audio passthrough only to desktop speakers you can use audio from a DP or HDMI output which most video cards support. If using the video card you must also select it in playback devices.. it does not use the motherboard audio chip)
https://www.newegg.com/Product/Product.aspx?Item=N82E16812186035&cm_re=usb_audio-_-12-186-035-_-Product
Has pretty great reviews. I saw the other SYBA product above, but this seems to have better customer feedback. No need for volume control for a desktop device as you'd do that in software (audio icon), as well as the desktop speakers.
Depending on how load the desktop speakers go, you might just set the audio link to 50% then use the speaker volume knob to control audio.
If you need cheap speakers too, make sure they have a headphone jack at least.
Type "Device Manager" into the start menu. When it opens up, right click on the drivers you're missing, click "Properties". Then click on the "Details" tab, and on the "Property" dropdown menu, make sure "Hardware IDs" is selected. Once selected, copy and past one of the IDs that are listed and past them into Google.
Or you can right click on the driver you're missing, and click "Update driver" and then select "Search automatically for updated driver software". Windows 10 in my experience has always been able to find 95% of missing drivers.
PCI\VEN_14F1&DEV_1033&SUBSYS_1500144F&REV_08
PCI\VEN_14F1&DEV_1033&CC_078000
This is the code that it shows up in hardware ids
Yeah that isn't causing the no sound issue. Your speakers must be broke or something.
