Just installed ATI All In Wonder Radeon 7500-running 98se-ViewSonic A70 monitor. I had an ATI All In Wonder 128 Rage Pro prior with no problems. Now I cannot adjust my refresh rate. It seems to default at 60Hz from the Radeon 7500.I've updated my monitor drivers, checked "Display Properties > Settings > Advanced > Adapter" (here I can adjust refresh rate but it doesn't take !! ) Also when I go to "Display Properties > Settings > Advanced > Adapter > Display" (Display is a tab installed from ATI drivers) it shows 60Hz with no place to adjust refresh rate. I've also tried changing Monitor types through "Device Manager" but no matter what I do it seems to always default to what I think the video card default value is, 60Hz !!! Do I need to make a registry change ? P.S. - I don't think my monitor is a "DDC" type monitor ?????? Thank you for any assisstance you may be able to offer !!!!!!!!! Kent
