Please HELP! Registry issues
Darthbill
11
Okay. So my initial issue was a usb 3.0 drive not working with usb 3.0 devices. The forum post is here
http://www.tomshardware.com/forum/296615-32-passport-recognized#t1982998
As you can see it wasn't resolved. As I searched further, I found that my driver wasn't changing after running the latest driver updates. I have a sony vaio, so i talked to sony support, gave them control, and watched them attempt the same fixes. Of course they ran into the same issue of the driver not updating properly.
So the support guy downloaded "PSTool" (premium services tool?) which supposively scanned my computer to find out how it was performing and to find any conflicts. At the end of the check, the support analyst (a new one) introduced himself as a technical engineer and said that the registry was corrupted. The program said (with problems bolded):
Performance Scan powered by iolo®
Internet Speed - Your Internet configuration is not optimized for maximum speed
Memory Levels - No problems found
Startup Speed - No problems found
Registry Errors - Your computer has 209 registry problems
Drive Corruption - Errors were detected on your system drive
Security Holes - Your computer has 13 repairable security vulnerabilities
System Clutter - Your computer has 987.56 MB of system clutter
Internet Clutter - Your computer has 195.36 MB of system clutter
Shortcuts Check - No problems found
He then said the fix would be $119.98! It was a guarantee fix with a refund if it didn't work, so i'm sure he could have fixed it, but I don't have $119.98 floating around. Who does?
Does anyone have any suggestions on how I could do this fix myself? Any and all help would be wonderful.
often drives disappearing is cause by the upper and lower filters being erased. this is often the case when you install a newer o.s that wasnt released for your hardware. typically the issue is found on xp issued machines running windows 7 so at a guess you have recently upgraded your o.s and you now find your hardware is disappearing randomly.
if this is the case all you can do is switch back to the original o.s that the lappy shipped with.
I have to agree with the majority that while Performance Scan may be a tool that they use, but the charge associated was simply a marketing gimmick. I did a Google search for Performance Scan by Iolo and sure enough, no such program exists. They only have System Shield & Anti-virus and System Mechanic.
CCleaner is a good free alternative to handle your junk files and your registry issues. You can also try System Mechanic by iolo if you want. I use it at home and it does wonders if you start noticing some slow downs.
I ran the CCleaner to clean the registry to find no change. The usb 3.0 driver still won't display the update after installing it and my usb 3.0 external hard drive still isn't seen (as explained in the other forum I linked).
Edogawa: That is the place where i've been getting the device drivers from. After I run the executable and restart the computer, I go check the device manager and check the usb 3.0 hosts properties and it says it is still at the previous version.
Hexit: I haven't upgraded my OS from a previous version. I bought this laptop with windows 7 64bit on it.
Any other suggestions on what I can attempt to make the usb 3.0 work?
