Please Help - Updating build
Rix77
Gday,
I have recently purchased a Noctua NH-D15 & a Gigabyte GTX 960 4gb Windforce for my rig, both to go on a Gigabyte GA-H77M-D3H motherboard. Unfortunately i've discovered that the backplate on the GPU touches the fan clips and the heatsink on the CPU cooler. Besides it being a really tight fit, is the Backplate touching going to be dangerous to the point I need to isolate to 2 components? I've read on some sites as its a Backplate it will be OK but I'm not sure as some of the screws holding the Backplate on go right through the GPU pcb.
