Please help with a 780TI overclock using Evga precision.
Footyslayer
63
Hi everyone, I have decided that whilst I await the next lot of Nvidia cards I want to overclock my GTX 780TI.
I currently have the "Inno3D iChill GTX 780 Ti DHS HerculeZ X3 Ultra" card and it runs as stock...
Voltage = 1.175mV
Clock speed = 1085MHz standard but hits 1201MHz on boost
Memory = 1800MHz
I am looking at using Evga Precision X for the overclock and will happily settle at about 1200mV on the voltage. So I will be looking for a little guidance along the way if you all don't mind? 😀
Firstly I have now added +25mv to the volts on evga precision but when under stress it still only shows 1175mv and not 1200mv, aIl I see there is overvoltage, overboost and KB Boost, which should be used for applying a voltage change?
Or with this card already being quite high on core and memory should I just leave it as it is? Oh and could the card be voltage locked at 1.175mV as when I try to add an extra 25mV on overvoltage when under stress it doesn't recognise the extra 25mV...
Hi, I have used MSI afterburner also but even when adding a voltage increase with either software when running any tests to check stability the card doesn't ever show as higher than 1.175mV.
It's really odd....
Thanks for responding, I have re-installed msi afterburner and made sure "unlock voltage control" is ticked. This hasn't helped though, I am still only seeing 1.175mV under load when I should be seeing 1200mV with my changes.
I have read that 780ti'S should allow you to go to 1212mV without having to mess around, I just can't get it to register my changes...
