Please help with build!!
Aman_33
34
I am pairing an Antec VP 500PC with this!!
Please help !! I will upgrade anyway in a couple of years!
My system is GTX 1070
I5 6500
Asus z170
Please help if this is a good PSU!!!???
Virtual_Singularity
Respectable
Feb 18, 2016
461
57
It's a psu. Is it a "good" psu? I wouldn't go that far, if we're comparing it to others. 2 year warranty doesn't inspire much confidence tbh. The psu is the heart of your system after all. To be sure, there are far worse, and far better. For the price its going for, spending maybe a tad more on a better psu would likely be a better choice.
Aman_33
34
Cooler Master b500 ???
Virtual_Singularity
Respectable
Feb 18, 2016
461
57
Not a big fan of CM psus tbh, and the v2 model seems a bit overpriced, unable to find original. Here are some helpful links:
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
http://johnnylucky.org/power-supplies/psu-recommendations.html
Also check johnnyguru.com & Tom's recommended psu page. Lot of sales out there, and also consider the motherboard and chipset, though here you shouldn't run into a problem, but it's always best to make sure about compatibility before ordering, rather than order and find out the hard way you chose wrong. I know it'd be a lot easier to simply name a power supply, and I will, but the above info in the links is good to know for anyone who may want to know in regards to psu overall quality.
CORSAIR CXM series CX550M isn't too bad for a bronze psu for the price, though I'd go for the RM550x or better if possible. SeaSonic G Series SSR-550RM also not a bad value for the price, $60 after $10 rebate. EVGA SuperNOVA 550 G2, around $80ish, 7 yr warranty. If you like CM theres the Cooler Master G550M, semimodular, though priced similarly to some others listed above that offer more value for around the same price. Btw, this is just my opinion. Plenty of people choose the cheapest PSU they can find. All I'm saying is it's better to remember the importance of the component, that it's worth getting the best one you can for your budget.
Aman_33
34
Antec VP or Corsair CX?
akash.singha777
7
hello.. i need an help from you regarding the pc you were talking about that contains an Antec vp 500pc... i am going to buy an ups for that psu.. but many forums are stating that it will not work only with a pure sine wave ups which are too expensive in my country... instead i was thinking of buying the stepped sine wave ups that are lot cheaper like the apc ones... can u please tell me what are your suggestions according to your build and what UPS have you used in the build??
-Regards
