please help, with gaming build
i will vote for the 2nd build.
There is not much difference between the 3 builds just two of them has i5 4690 and one has i5 4690k plus 3rd has a SSD.
So for best performance the 2nd build is my pick for obvious reasons.
Plus you can use the 650 watt PSU for all the 3 build and still left with enough headroom for SLI.
so i wouldnt need a psu of 750w, if i want to ( which i will) put in a second graphics card?
Cause ima get the phantom full tower and i want to put led strips and all the led fans it can fit . i think its 6. So it will have enough power for all of that?
