Hi:
I own an ASUS M3N72-D motherboard for my AMD Phenom II X4 940 BE processor, and I recently sent the motherboard to ASUS for repair because it was not working. The green light that is supposed to be solid green on the motherboard was flickering, and the motherboard would simply not power on. At first, I thought it was the PSU, but after testing (used a multimeter to ensure it was fully functional, and attempted to power on the PSU without the motherboard using the 15th and 16th pins on the 24-pin connector) I found that the PSU was fully functional.
I tested the motherboard with nothing but the CPU and two sticks of RAM, then one stick of RAM, then nothing (no cpu or ram). All of these resulted in the flickering green light which was not allowing the motherboard to power on. During original testing, with the motherboard still in the case, my cousin and I were just turning the power on and off to see if we had any luck and the entire computer including the motherboard powered on ONCE with no RAM, but everything else on (CPU, GPU, soundcard, heatsink). It gave me the usual beeping noise to tell me there was no RAM, and after we turned it off to try and see if it worked again, it discontinued working. We tried with no RAM several times, thinking it was the RAM but to no avail.
After sending the motherboard to ASUS and explaining the problem to them, they were able to "repair" it in just a few days and I just received it back today. It still has the same exact issue. I have contacted them and they are putting me through a process where they'll check their stock to see if they have my motherboard in one of their facilities and they will then send it to me.
Am I missing anything here? If the motherboard was fully functional and it was indeed my CPU (which makes no sense to me since it turned on that one time) would the green light be solid without the CPU on? The CPU appears to have no physical damage and no signs of overheating.
Any help would be great,
Thanks in advance.
edit: typos
One quick note I didn't mention: the computer in question was unused for a little under a year. I did not clean it until last week when I was testing everything. There was accumulated dust on the motherboard, but I dusted it all off using compressed air. Is it possible the motherboard short-circuited during that process? Unfortunately I do not have another motherboard to test any of my components on, or this would be far easier. However, everything did work the time it turned on.
Thanks in advance.
edit: typos
