Please help with my chkdsk read
Naduba
My computer is having some problems for a while. It is *very* slow sometimes, and get stuck so I need to hard reboot it. It happans a lot, and especially after hybernation. So, I made a disk check. What can I do? this is my disk check log:
Checking file system on C:
The type of the file system is NTFS.
A disk check has been scheduled.
Windows will now check the disk.
Stage 1: Examining basic file system structure ...
165120 file records processed. File verification completed.
1884 large file records processed. 0 bad file records processed.
Stage 2: Examining file name linkage ...
213938 index entries processed. Index verification completed.
0 unindexed files scanned. 0 unindexed files recovered.
Stage 3: Examining security descriptors ...
Cleaning up 40 unused index entries from index $SII of file 0x9.
Cleaning up 40 unused index entries from index $SDH of file 0x9.
Cleaning up 40 unused security descriptors.
Security descriptor verification completed.
24410 data files processed. CHKDSK is verifying Usn Journal...
37809016 USN bytes processed. Usn Journal verification completed.
Stage 4: Looking for bad clusters in user file data ...
Read failure with status 0xc0000185 at offset 0x37e2df000 for 0x10000 bytes.
A disk read error occurredc0000185
The disk does not have enough space to replace bad clusters
detected in file 45 of name \hiberfil.sys.
Read failure with status 0xc0000185 at offset 0x9f07350000 for 0x10000 bytes.
detected in file 55782 of name \Windows\System32\wdi\LogFiles\SECOND~1.ETL.
Read failure with status 0xc0000185 at offset 0x224a6e000 for 0x10000 bytes.
detected in file 75263 of name \pagefile.sys.
Read failure with status 0xc0000185 at offset 0x54eb589000 for 0x10000 bytes.
detected in file 98221 of name \Windows\System32\sru\SRUDB.dat.
165104 files processed. File data verification completed.
Stage 5: Looking for bad, free clusters ...
147300688 free clusters processed. Free space verification is complete.
Adding 8346 bad clusters to the Bad Clusters File.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Windows has made corrections to the file system.
No further action is required.
711423999 KB total disk space.
121852556 KB in 121093 files.
78188 KB in 24411 indexes.
33384 KB in bad sectors.
290499 KB in use by the system.
65536 KB occupied by the log file.
589169372 KB available on disk.
4096 bytes in each allocation unit.
177855999 total allocation units on disk.
147292343 allocation units available on disk.
Internal Info:
00 85 02 00 6b 38 02 00 65 40 04 00 00 00 00 00 ....k8..e@......
98 00 00 00 31 00 00 00 00 00 00 00 00 00 00 00 ....1...........
Windows has finished checking your disk.
Please wait while your computer restarts.
Thanks a lot,
Nadav
Hi, Thanks for your reply.
I recently formatted the computer.
I have 562GB of free space.
Thank you very much for you diagnosys.
I also received a windows messege alert the morning after the dskchk, saying "windows detected a hard disk problem. Back up your files to prevent info loss, and contact the comp manufacturer to determine if you need to repair or replace your hard drive"
I hace everything backed up. I think it's inevitable to replace the disk. I'm using HP Pavilion g series. How can I know what hard drive I need to purchase?
You can either contact HP support with your model number for that information, or take a look at the size of the drive.
My educated guess for the size of your HDD that you need to buy is any 2.5" drive.
So look for a 2.5" form factor hard drive, SATA, and I can almost guarantee that it'll work in your system.
