[SOLVED] Please help with specs
Aug 21, 2021
9
Please keep it to 1 thread
I’m looking to build a pc that can run games like fortnite and other shooter games at 120 fps or close to that. My budget is £1000 and I need someone to give me pretty good specs including case etc.
Hey there,
What type of monitor will you be using. Hitting 120fps is easy at 720p or so, more demanding hardware for 1080p. Also what graphical level are you looking for. High/ultra settings with lower FPS (all eye candy) or low to medium with high FPS?
Where do you buy from in the UK, or what stores would you use.
Also, right now with supply chain issues and high prices it's not a great time for getting a PC. Whilst there's lots of choice, getting hold of the parts is sometimes an issue.
https://www.scan.co.uk/products/fractal-design-focus-g-black-windowed-atx-mid-tower-case
Fractal Design Focus G Black Mid Tower Case £39.98
Exhaust fan for that case.
https://www.scan.co.uk/products/120...0rpm-563cfm-fluid-dynamic-bearing-black-4-pin
Arctic P12 Static Pressure 120mm PWM Fan 4 Pin £3.98
https://www.ebuyer.com/782056-corsair-tx550m-550w-80-plus-gold-power-supply-cp-9020133-uk
Corsair TX550M 550W 80+ Gold Semi Modular Power Supply £59.98
https://www.amazon.co.uk/dp/B08X7DBHS1/
MSI MAG B560M BAZOOKA £97.39
https://www.box.co.uk/Intel-Core-i5-10400F-10th-Gen-Processor_2939890.html
Intel Core i5-10400F £126.71
https://www.scan.co.uk/products/dee...-single-tower-aluminium-fins-4x-heatpipes-int
DEEPCOOL GAMMAXX GTE V2 CPU Cooler £19.99
https://www.ebuyer.com/1265314-king...-x-8gb-3200mhz-ddr4-ram-black-kf432c16bbk2-16
Kingston FURY Beast DDR4 3200MHz 16GB (2x8GB) CL16 £61.98
Crucial BX500 3D NAND 2.5" SATA 1TB Internal SSD £69.99
https://www.falconcomputers.co.uk/m...hr-12gb-gddr6x-pci-express-graphics-card.html
MSI Geforce RX 3060 Gaming Z Trio LHR 12GB Graphics Card £579.99
Total: £1060 inc VAT
https://www.msi.com/Motherboard/MAG-B560M-BAZOOKA
https://www.fractal-design.com/products/cases/focus/focus-g/black/
Something similar,
PCPartPicker Part List
CPU: Intel Core i5-11400 2.6 GHz 6-Core Processor (£184.98 @ CCL Computers)
CPU Cooler: CRYORIG M9 Plus 48.4 CFM CPU Cooler (£25.99 @ Amazon UK)
Motherboard: Asus PRIME B560M-A Micro ATX LGA1200 Motherboard (£104.10 @ Technextday)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (£57.99 @ AWD-IT)
Storage: Kingston A2000 1 TB M.2-2280 NVME Solid State Drive (£69.98 @ Ebuyer)
Video Card: ASRock Radeon RX 6600 XT 8 GB Challenger D OC Video Card (£389.99 @ CCL Computers)
Case: KOLINK Citadel Mesh MicroATX Mini Tower Case (£43.28 @ CCL Computers)
Power Supply: Fractal Design Ion+ 560 W 80+ Platinum Certified Fully Modular ATX Power Supply (£59.13 @ CCL Computers)
Total: £935.44
Generated by PCPartPicker 2021-10-17 14:43 BST+0100
Shows at least some other options, keeps igpu as back up.
Reactions: Roland Of Gilead
Hey there,
I’m looking to use a 1080p monitor, in the uk we have stores like curry’s pc world etc but I’m maybe looking to buy on Amazon or on other online websites but just want to at least get the specs best for suitable. Looking for low to medium with high fps. Please let me know if you can help and drop me some specs with case and all components. Thanks
The other posters, have given some good examples of what's available. Though designed around building it yourself. Is that something you want to try? It's a good way to go and keep costs down.
Here's a Ryzen build, instead of Intel based. Very strong for all games at 1080p high settings, and solid enough at 1440p.
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor (£259.99 @ AWD-IT)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard (£119.99 @ AWD-IT)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory (£64.99 @ Corsair UK)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive (£67.98 @ Amazon UK)
Case: GameMax Gravity ATX Mid Tower Case (£44.66 @ CCL Computers)
Power Supply: Corsair TXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply (£59.99 @ Currys PC World)
Total: £1007.59
Generated by PCPartPicker 2021-10-17 16:30 BST+0100
Could someone who is experienced with pcs tell me if my specs are ok, I’m looking to run around 120 fps on shooter games with a 1080p monitor. My budget is £1010
Please let me know if this is good enough or if there is any errors
I'm not sure I'd go for that case as it appears to have poor air flow. Keeping a steady supply of cool air will be especially important if you're using the (barely adequate) Wraith cooler that comes stock with a 5600X. In gaming action it just ends up recirculating the hot GPU exhaust...and it's own hot air...which will severely limit CPU boosting.
Reactions: Why_Me
Thank you, could you maybe refer me a better case please.
The only RX 6600 XT available is on Amazon UK for over 1000 quid. I'm guessing your budget has changed since your previous thread two days ago.
That’s great but you could maybe find a case in under £100 that’s good, even if you know it’s in the us because I could get it in the uk or find an alternative very similar to it, please and thanks
