Please help with suggestions and overview my build
lostjohnlocke
8
Hi there. I'm considering building a pc for the first time. I am looking to spend about 1-1,200 or a little more and I need everything, including the case.
If you see I am over my budget in the below things, I can go a little over.
Here is what I would like included with the build:
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115018
Mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128086
GPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130318
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
Optical
http://www.newegg.com/Product/Product.aspx?Item=N82E16827129018
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146047
Hard drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
How does this look? Is it all compatible? Thank you for any help!
shadowduck
2,641
Buy a retail boxed CPU not that OEM one you picked. It comes with no heatsink or fan and only a 1 year warranty. Boxed CPUs come with a heatsink and 3 year warranty.
Good choices mostly. PSU- Top-notch choice there. Motherboard is fine, you can get the DS3L instead if you don't need RAID and save money. Better idea would be to move to the new P45 chipset. Will only cost you $30 more:
[urlhttp://www.newegg.com/Product/Product.aspx?Item=N82E16813131299[/url]
RAM: Get this G.Skill kit: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231087
OR deal of the day:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227139
4-4-4-15 RAM 2GB for $28
Similar threads
