Archived from groups: alt.games.baldurs-gate (
More info?)
I ran TUTU_restore, then applied the baldurdash patches. Then I ran TUTU
again. TUTU appears to be working.
Once I get all the way through BG1 I'll probably do fresh install of BG2
before playing again.
The sequence of patches was BG2 & TOB, followed by Bioware's TOB patch,
followed by the baldurdash patches. Was that wrong?
Also, do I apply WeiDU mods after applying all these patches in this
sequence? I'm thinking to do the Sola mod and a few others.
Thanks for the help.
Adam
"Wim Dekker" <someonenot@microsoft.com> wrote in message
news:41cfe7e8$0$91237$ee9da40f@news.wanadoo.nl...
> Another careful reading of the Tutu readme will probably show that the TOB
> option is
> not available while playing Tutu
🙂. Did you apply the Baldurdash patches
> while Tutu
> was still installed? There is only one save way to apply them: after a
> fresh installation
> of BG II and TOB, _before_ any other patch.If I were you, I would start
> again: first
> remove all BG II and TOB software, then install it again, then apply the
> Baldurdash
> pathes. Next are patches that don't use Weidu. Ah well, it is all
> explained in the Tutu
> readme files.
> Wim
> "Adam Christopher" <adamandeaster@verizon.net> wrote in message
> news:Lvzzd.11795$2X6.3857@trnddc07...
>> After carefully dissecting the various Readme's (who reads them anyway
>> until there's a problem, right?) I got the Baldurdash patches for TOB.
>> This seems to have fixed my problem below.
>> I have another question though. Before reinstalling TUTU I started BG2
>> and the option to play TOB was gone. Anyone else seen this problem
>> before? Will it come back when I do TUTU_restore? Or will I have to
>> fully reinstall TOB?
>> Thanks,
>> Adam
>> news:dQpzd.7049$hc7.6774@trnddc06...
>>> Everytime I exit the crossroads to go to the Friendly Arm Inn, the game
>>> crashes. I need help!
>>> I have TOB installed with Bioware patch. I have Tutu with Tutufix_5.
>>> I just got BG: Original Saga and am trying to Tutu it. If there's a FAQ
>>> or other info someone could direct me towards, I'd greatly appreciate
>>> it.
>>> Thanks,
>>> Adam
